Can't enable debugging *Solved*
I’m having a few problems but i’m only going to list my debugging issue. I’m going through the troubleshooter and one of the steps “Turn on debugging” takes be to the url http://display.dev/fault/debug/on?. This in turn reports a 404 “Page not found”
I found the problem. Bad clone and merge had a merge conflict that wrote to js files.
