Can't Connect to Xibo outside of host
So, I installed Xibo using this tutorial: https://www.linuxhelp.com/how-to-install-xibo-cms-1-7-7-on-centos-7
on a vanilla Centos7 install. The installation work fine, but I can only connect to the web server from the Centos machine. I’ve tried turning off the firewalld service and iptables is off, however I still can’t connect to it. Anything else I should try?
