I created a campaign, assigned it 2 5-minute layouts (the first 3 minutes and the second 2minutes) and programmed it to display on a device for 10 minutes it loops exactly as you described in an old topic about the campaign looping. layout 1 layout 2 (the same order as in the campaign) but it does not return to the layout 1 and stays on the layout 2 until the 10 minutes elapses. What is the reason for this bug and how can I cope with it!
Thanks and best wishes!
Are you absolutely sure that the second layout is only 2 minutes?
The Player doesn’t see the Campaign, it only sees 2 Layouts that should be cycled until the schedule ends - so unless the second Layout lasts longer than you think, i’d expect this to work.
If you think its right, please send us both layouts via PM to transfer.xibo.org.uk
Best wishes to you too!!
Okay thank you so much! It works now I do not know what happened I rescheduled it and it loop.
Thank you very much and sorry!
