Is there a way to bulk delete media? I have quite a few images to delete and deleting them individually is going to take a long time…
Unfortunately no, it’s not available.
Although if those images are no longer assigned to any layout you can run library tidy which will remove all files that are not in use.
I agree this is something that needs to be added to the system, along with being able to bulk change duration, Transitions In and Out, and a few others that would much help to speed things up.
If you could please create a new topic in the features category and mention your requirement with the use cases, then we will certainly keep it in mind for the future development - it is not guaranteed that it will be implemented, but it would be much better to have that nicely written in the features category please.
