[BUG] RespectSanitizer truncates base64 data inside img-tag
Windows .NET
I confirmed a bug with the RespectSanitizer which is used inside the RemoteDataset Fetcher. I have custom HTML datasets which holds some <img src="data:image/png;base64,…
And it turns out, when I remove the sanitizer (I pacthed the line to just assign $value[1]) it works like before.
I also found this: [Html Sanitizer] Sanitizer corrupt image if src scheme is data · Issue #49040 · symfony/symfony · GitHub
So, I dont know if you can adjust the sanitizer for base64 images or maybe we can get an expert option to trust these data and NOT sanitizing them?
Cc @dan
AH I just saw the comment: [Html Sanitizer] Sanitizer corrupt image if src scheme is data · Issue #49040 · symfony/symfony · GitHub
So it seems a input length issue? Did not tested it. Could you provide a test pathc for me to test?
