Hello everybody.
Have anyone seen this before?
Player and CMS 1.7.9
Hello everybody.
What Windows version are you using please?
Do your system meets the requirements - http://xibo.org.uk/manual/en/install_windows_client.html
I guess this error might be .net framework related, you could try to uninstall it -> reboot PC -> download and install it again from MS pages.
Hi Peter. I’m on latest windows 10, i will check .net. Thanks
Are you on a standard release? Or do you have a debugger attached?
I had .NET 4.6.
I re-installed Xibo and the error is gone, thanks anyway
