Hi i’m using 1.8 and want to change my host. So how could i do a backup and restore the data/mysql on a new system?
Hi
if you want any help, please let us know, what’s your System?
Windows? Linux? what DB? What envinronment? Xammp? IIS? Appache?
Some short Steps:
Copy your Xibo Folder, your DB-Dump, and your Xibo-Library to the new System and let it run…
Maybe you must edit your settings.php in the /xibo/web folder…
Greetings from Germany
Torsten
Hi, yeah, you’re right, i forgot this: Linux, MySQL on an other Maschine, Apache.
Okay, if it is so simple it should be done as short as i setup it up.
Thanks and yes, greetings to Germany
