HI all. Is it a way to have a different background color on a region, that would be different from the background of layout?
Viper92
I’m by no means a Xibo expert in fact I’m closer to a noob. But what I did to create the illusion of different backgrounds on different regions was create a master background jpg using Photoshop with the different areas I wanted to put a region and uploaded that as the background for the layout then just created a region for each block and left the background of the region transparent. If I wanted to change the background for the region I would edit the Photoshop document and save over the background.jpg. There may be a more direct way of doing this but I found this worked for me. I hope this helps.
Thank you! I will try it.
