Atualização Cliente Android
Ola Dan,
Necessito de mais informações sobre atualização de versão Cliente Android.
Para atualizar a versão cliente android 1.7 para a nova versão 1.8 , o valor e igual da compra de uma nova licença???
Não achei nenhumas informações sobre esse assunto.
Muito obrigado
If you have Xibo for Android licences purchased recently then they came with free upgrade to 1.8 version.
If you have older licences, then you’d need to purchase a paid licence upgrade to use them in 1.8 version.
After 1.8 release, if you purchase Xibo for Android licences then you will be able to use them in 1.8 version.
As for the application itself, you will upgrade it just like before - download new apk and install it on your device - if you have rooted devices then you can also upgrade them via CMS.
