I am trying to use postman to connect to the API. I have followed the below steps
Create an application in myCMS. Key & Secret has been generated to be used for API calls.
I have added the url (My CMS URL), clientId (Application Key), clientSecret (Application secret) and access_token (Blank) in the environment of Postman.
Call Type “Post”, Request URL “{{url}}/api/authroize/access_token” and send the request and received the below error
The above is for 1.8 API, if you’re still using 1.7 series, then please have a look at links provided by Dan in your previous topic - Client id and secret as the urls etc will be different.
If you want to use API then as Dan said we highly recommend upgrade to 1.8 series.
