Hi to all.
I upgraded version 1.8.13 to version 2.0.3 and in the “Layout” tab I can’t find any of the previously set layouts.
If I go to the schedule or if I create a new schedule I can select the layouts I had.
What’s the problem???
Hi to all.
Thank you for your message. In your second screenshot, I can see that no Layouts are showing, could you click the Advanced tab shown in that screenshot and send a new screenshot to show that there are no filters filled in there?
OOOOPS:… it’s filtered on “retired” by default…
sorry …
and thanks so much…
No need to apologise, glad that the issue was caused by the filter rather than your Layouts actually being missing.
