Hello i have client that will use TV build with android itself and he wants to be able to reboot player remotely.
Is that even possible or not ?
I have tried to setup xmr but no luck and what are command for android.
That might depend on the device itself, usually just:
svc power reboot
should work or just reboot
and preferred would be
svc power reboot
am start -a android.intent.action.ACTION_REQUEST_REBOOT
setprop sys.powerctl reboot
reboot
^ as one command string.
