Android Status info available through CMS
#1
On the android APK if you navigate to a clients “status” tab it gives you a useful textbox full of status & general information.
Is this information available from the CMS in a similar high density format?
Recently it was helpful especially to see that some of our displays had blacklisted 2 .pngs - and this wasn’t obvious from the display screen in the CMS but it was very apparent on the android units status splash.
Thanks!
#2
It is indeed possible to collect and view the same Status information within your CMS. How to do this is exaplined in the below Guide:
Please note that we are currently updating our Manuals and Guides to reflect the changes to the CMS. I mention this because there are some elements in this Guide that are set to be Edited. For example, you will not find:
Enable auditing in ‘display’ page - go to ‘displays’ -> edit your
display device -> go to Advanced tab and set Auditing to ‘Yes’
Instead you will see Audit Until fields, where you can set a period for Auditing to be on instead of a Yes/No option.
