We have Xibo android client installed on multiple Philips TVs. The client and the connections work fine but sometimes, when the TV is restarted, it forgets the default app, which leads to the TV prompting if we want to open Xibo or Android default home. This is troublesome, because we need to manually go to the TV and select the home app before it proceeds to opening Xibo. This happens despite us selecting the “Always” option during the prompt.
Has anyone else ran into this problem? If yes, how did you solve it?
I’ll add an image that shows the prompt where the client gets stuck.
We’ll try the workarounds you suggested. It might be possible that the TV just doesn’t understand the “Always” option, so we’ll first try to change it from the settings. Do you have any recommendations for the second option?
