For some reason I’m unable to set default home app with our Philips TVs and it causes the player to get stuck, while booting up, into the screen where it asks which app it should use as the home app. Has there been any new solutions I could try to eliminate this problem? As far as I know it would be enough if I could disable the check altogether, since Xibo starts itself in any case after the TV is on, is this possible?
Thank you for letting us know about this issue. Could you open a ticket on the Xibo help desk and address it for the attention of Daniel? Please make sure to set the Help Topic as Technical Support.
