Hi, I would like to welcome everyone on Xibo Community !!
I bought from china 2 headrest for taxi with android screen inside, my plan was to instal xibo for android v1.8_r106. Unfortunately my android is to old ( 4.0.4) for that version of APK - “Parse error”. Is there any chance to get version xibo for android what will work?? on my Xibo will be just simple slide show (jpg’s) ?? Please give me some advice.
Radek
Andorid 4.4 is the minimum required to run Xibo for Android 1.8.
Xibo for Android 1.7 should be able to run on the device though, and so you’ll need a 1.7 series CMS to go with those. You can use 1.8 series licences to licence your 1.7 series Players.
