Have created a new event
2018-09-15 to 2018-09-17
Repeats monthly
nothing is displayed in the agenda for 16 September, 2018
Did I do something wrong ?
Best regards
Hubert
Repeats monthly
Best regards
Hubert
Thank you for sharing the screenshots. I’m trying to replicate the issue on my CMS, however I am able to see the Event.
Can you confirm that the scheduled layout is valid and has no issues displaying?
It’s my mistake, a campaign was planned, but someone removed all the layouts from the campaign. Therefore, nothing is displayed in the Agenda.
But I have another problem.
A new event. But now with content. From 2018-09-15 to 2018-10-05
Until 2019-04-01
View September 2018 is OK
View Oktober 2018 is OK
View November 2018. The days until 2018-11-05 are missing.
Am I doing something wrong again?
Best regards
Hubert
The issue you are experiencing is caused by a bug. I have linked the bug report below:
Thank you for bringing this to our attention, we will resolve this issue as soon as possible. In the meantime, I would recommend scheduling events that span a single month until the issue is resolved.
With your schedule, I would recommend creating an event that is set to run from 15/9/18 until 30/9/18, but not to repeat. Then create an event from 1/10/18 until 5/10/18, to repeat once a month until 1/4/19. Finally create an event from 15/10/18 until 31/10/18, set to repeat once a month until 1/4/18.
The reason I suggest creating a separate individual event for September is because there are 30 days in the month. If you set this to repeat, it will not display on the 31st of the following months. As October has 31 days, you can set this one to repeat to ensure all days are included in the future.
from 15/10/18 until 01/11/18 00:00
Then it should be correct for all months
You are correct, you can also set it this way.
here and previous months still right
But 15. Oktober 2019 suddenly until 2019-11-02
In your message you have stated the event date is:
But the screenshots are for dates in 2019. Previously in your messages you had set the Until Date for the Events to be 1/4/19. Can you provide screenshots of the Edit Event Page as before, including a screenshot of the Repeats tab?
Thank you. And also the General tab please.
The issue you are experiencing is also a bug and has been reported. I have included a link to the bug report below:
Thank you again for the information you have provided, we will resolve the issue as soon as possible.
