When I create a new event and press next and then save, the event will be saved twice. Is it okay for this to happen, or is it an error?
It should create one event, do you perhaps have the start/end (or repeat) set to cover more than one day?
In this case it will show the event for all selected days.
Perhaps a screenshot presenting your issue would be helpful.
I think is no error
next = save
Exampel:
Add Event
Start 2017-08-14 00:00 End 2017-08-15 00:00 then press next
Exchange date and time for another event
Start 2017-08-21 00:00 End 2017-08-22 00:00 then press save
Now you have created 2 different events
Yeah hhan might be correct on this one, the Next button is functionally the same as Save, but it does not close the form.
So if you did click next and save that will create two events.
Exactly. I don’t see the need for the existence of the ‘next’ button as an option on this form.
You don’t, many users do, as it might be easier to create multiple events without a need to close/open the addEvent form.
Ohh yeah… now i see the usability… thanks!
