Adding a Event Problem
Hi
i have a little problem if my User want to schedule an Event.
If i go to “Schedule” -> Choose the Display and after that, klick on “Add Event”.
The “Schedule Event” screen show up and i can add the Event and make a Save it works fine on the choosen Display.
But: When i go to “Schedule” and chose direktly “Add Event”, in the Dop-Downfield of the Display is no Display shown or chooseable
Is this a bug or a permission proplem ?
Sunny Grettings from Germany
Torsten
My guess is that you’re using a User/GroupAdmin user type there no super admin( there should be no issues with super admin), and therefore you’ve encountered this bug - https://github.com/xibosignage/xibo/issues/1607
If you’d give your user permissions to campaigns/displayGroups then it should work fine in current version and will be fixed in 1.8.12 as per the linked GitHub issue.
Hi Peter,
Thank you for your answer. With the permissons for campaigns and displaygroups it works.
