Currently i’m using xibo 1.8.7 as Xibo CMS,
when i’m tyring to Add Schedule using API
i got this message “Page not found”
and here below , the parameter list i have POST
So how to fix this ?
anyone can help to fix this issue ?
Generally if you’re trying to ADD something then you should use POST call with form-data
- https://xibo.org.uk/manual/api/#/schedule/scheduleAdd
The PUT call is for EDIT and it also needs x-www-form-urlencoded
, you’d use that to edit existing event for example - https://xibo.org.uk/manual/api/#/schedule/scheduleEdit
Other than that.
The displayGroupIds is an array of integers, as such in Postman it is represented as
displayGroupIds[]
Assuming that campaignId = 11 exists - either as an actual campaign or as a layout specific campaignId, then it should work fine with the changes I’ve mentioned above.
Hi Peter,
Ok, thank you for your advise
it seem i got wrong when using CALL mode
I supposed using POST to ADD Schedule
Thank You
