Olá, Queria saber como fazer para acessar o layout direto da URL?
Can you provide more information about what is meant by the direct Layout of the URL?
Então quero ter acesso aos layout do xibo utilizando o navegador (digitando o caminho)
“Onde fica armazenado esses layout do xibo para obter o caminho?”
Your Layouts will be stored on the computer running your CMS, at the location you have set for the Library.
I am using a Docker Installation, which stores the Layout files and Media at the shared\cms\library directory. Where your Layout files are stored will depend on your setup and how you have configured your CMS.
Olá, Bom dia…
E como eu faço para acessar esses layout a partir do xibo player ?
Att.
Once you’ve created your layouts, you would schedule them on your Xibo Player to show them. Xibo will take care of transferring what is needed to show the content automatically.
You open the Player settings and enter the URL and key for your CMS.
If you’re hosting on Cloud, then those details will be in your welcome email. If you’re hosting yourself, then you’ll know where you installed the CMS. The key you can find on the General tab of the CMS settings page.
Agradeço por está me respondendo…
Eu fiz exatamente isso porém aparece a mensagem “Impossível conectar-se com o servidor remoto”…
Já não sei mais o que fazer…???
You likely have the wrong address in there then.
It needs to be the same address as you use to connect to the CMS login page. eg https://myserver.example.com
Então estou colocando o endereço que eu conecto na pagina de login
http://localhost/xibo
E mesmo assim não da certo…
So that address will only work on the computer you’ve installed Xibo CMS on.
From a remote machine, you’d need to put http://192.168.1.10/xibo
where the IP address is the IP address of the server machine.
Olá Boa tarde…
Queria agradecer pelo suporte, deu tudo certo até então a instalação e testes iniciais, agora vou conhecer as funções que o xibo possui.
Thanks for the update. I’m glad you were able to get it working.
Olá Boa Tarde
Estou trabalhando com o xibo alguns meses e me surgiu um desafio agora de instalar o xibo no linux, porém tenho que fazer isso acessando o linux utlizando apenas o ip do servidor que devo instalar mais o login e senha claro, alguém pode me ajudar???
