I am a script newbie so the solution may be obvious to you.
I have grabbed a weather widget from accuweather and set it up in an embedded region. It displays fine in preview, but on the player, the widget only flashes up for a fraction of a second at the end of the layout duration.
I’d prefer not to use the iframe workaround I read about elsewhere in the forum, because I have other needs for embedded html, and would like to learn how to make it work.
Is some script command required to get the page to paint?
Here is what I have…
