Hi
How I can use the weather widget by adding all cities for the specific country and preview 5 cities (for example) on 1 page and the duration between every page 10 seconds (for example)?
Regards
Hi
Regards
Hello, it depends on how you want the Weather to be displayed. If you want the weather forecast to change to show each of the cities (like a slideshow) then add the weather widget to the same Region and then configure for each city, setting the required duration:
Or if you wanted them to all be visible that add 5 Regions and add a Weather widget to each Region for each city.
Thank you Natasha
but can I use API?
Regards
Yes you could use the API. All development documentation can be found here
Thank you
