4k Portrait Android Client
Hello!
I’m having the a problem: 4K 75" screen and android player running on beelink GT1 Ultimate.
I’m running it on portrait mode and with 1080 layouts, it runs ok. With 4k layout runs ok too but only if the contents inside are 1080. If i put a 4k content it won’t play.
I’ve forced the screen dimensions to be 2160x3840 as it appeared 1080x1920 before doing so. I’ve changed the layout to 4k, i also created my own 4K resolution as the original wasn’t working but i end up with this same result: only 1/4 of the layout appears… It looks like it is set for 2x2videowall and it’s only showing monitor 1.
Any ideas on this?
Thanks a lot!
I wonder if it is actually capable of displaying higher resolution than 1080p or is it only capable of upscaling it - which could explain your issues if that’s the case.
Could you check/show us how does the display settings look like on the device itself.
Then when you assign the 4k profile to the player with 4k layout, could you open status window and show us what does it say there?
Here are the results
First:
1080x1920 with same specs layout
second:
monitor override 2160x3840 with 1080x1920 layout
And here the results after rebooting, with 4k Layout and auto best resolution
