Is it possible to run the 2.0 Beta on a synology I have tried but I get connection refused when I try to login to the CMS. I Installed the image and linked it to the previous folders and database using the same settings that I used when I installed 18.1 would this be the best way to do it?
Whilst Synology is not an officially supported platform, other users have had success installing and running Xibo on it. I can see in the Guides section of the Forum that a User created a Guide on how to set up Xibo on Synology. You may find some advice from those users that created/commented on the Guide.
