Yes - the name of the file in temp is exactly “OpenSans-Regular.ttf”.
I suspect that something in default installation of XAMPP might be interfering with fonts installation/rebuild module but as you see all Xibo prerequisite tests are passed. I haven’t manually disabled any system calls.
This change partially helped.
The file is now copied and the font is visible and working.
The problem is that fonts.css file is generated in /temp (and is seems OK - it contains the new font) but it is not moved to library folder (the original file is still there).
But with the wrong file in library ckeditor works fine with the new font so it is not a very big problem.
I think you will find that the font doesn’t work on the players - because they use the fonts.css file in the library. We’d need more logging to determine why the fonts.css file doesn’t get moved… I am suspecting a different issue.
You are correct - the player doesn’t display the new font.
I have moved the correct fonts.css file to library folder but that did not help.
In the player’s library folder I can see that new font file is downloaded by the player but the fonts.css file is not updated.
If the problem also occurs here then it would be easiest to get some logs by taking this transaction with logging switched on. Please can you use the report fault process as before?
We are almost there
The file is now properly generated and copied to library (during font upload and fonts rebuild as well). The only problem is that it is also left in the temp folder…
I have tested the display - the files (fonts.css and font file) are properly downloaded.
There is a problem because the font is still not used in the presentation but perhaps it is a different problem.
I will try to fix it myself.
