i have 1 Data Set which is setup in Layouts, example of dataset below
However Windows xibo player is showing it as a blank page
I am using xibo cloud hosting for this
Are you using any filter on that dataset?
Could you please create new clean layout using your dataset, for now without any filter and see if it will work?
It seems to be working fine in our test environment.
