1.8 alpha 2 configuration error
I have been using 1.7.6. I have a test server setup for 1.8 alpha 2. I get a configuration error after attempting to setup path to media library. I can not continue nor can I go back.
Configuration Error
Problem moving provided file into the Library Folder
The path in the address bar is /web/login.
Database has been created and I attempted to input the path in the settings table. What can I do to either restart or resume the installation?
Sorry I got it…I mistyped the path to the server root.
