According to the Task section our task are running, but the notifications are not being cleared.
We had a problem a while back with the task not running because our password was not in an acceptable format. We fixed that months ago, and the task started working. But now, the clearing of task is not happening. We have over 5000 notifications. Where should we start looking to correct the problem?
SELECT COUNT(*) FROM `notification` where releaseDt < '2017-09-22 00:00:00';
SELECT COUNT(*) FROM `notification` where releaseDt > '2017-09-22 00:00:00';
That should give a number of notifications that are older and newer than the 7 days you have configured.
I have not had the time to try what you suggested Alex. But I did see that the notifications have been reduced by about 5000. Not sure what happened. Maybe some sort of glitch. If I notice it again, I will see about connecting the sql database and see if I see anything strange.
