I am currently running 1.8.0rc2 using docker. I am trying to upgrade to rc3 with docker compose.
I have read through the steps here, and when it says “Replace the contents of your Docker files with the new release archive for 1.8.0-rc3” I assume this means replace the xibo-docker-master folder with the new xibo-docker folder. My DATA_DIR is located at /opt/xibo, and I backed that up as well.
When I run docker-compose up after updating the MySQL password from my old launcher.env file, the install completes, but it doesn’t do an upgrade, it does a brand new install. I don’t see an option in the new config.env file for defining the DATA_DIR, so I assume the issue is that it doesn’t see my current MySQL DB, and that is why it fails at the step to check cms-version with “cms-version doesn’t exist - New install”
Do I need to stop the current Xibo, then move the DATA_DIR somewhere else?
Should I have placed the contents of the xibo-docker folder inside my existing xibo-docker-master folder?
Sorry that I am not understanding this process, I really hate to keep bothering you all, but the steps are not clear to me.
I am already running 1.8.0rc2 using docker, why would I need to download 1.8.0? and I just asked about the change to docker section above. Those steps are not clear to me, and that is why I posted this.
The issue you have is because using the old “launcher” method we were able to separate the location where you stored your data /opt/xibo and the launcher file.
We no longer support that from rc3 on ward as there isn’t any sensible way to do that with docker-compose (however the other benefits far outweigh this).
The key information is that the contents of the xibo-docker archive must be extracted into the same location as your data folder root - i.e. /opt/xibo
Ok, so I have figured it out by doing the following:
Dropped the files from the new xibo-docker folder into my existing /home/ubuntu/xibo-docker-master folder. This action is for step “Replace the contents of your Docker files with the new release archive for 1.8.0-rc3” That might be self-explanatory to most, but it wasn’t fully clear to me. Then I moved my shared folder from /opt/xibo to /home/ubuntu/xibo-docker-master/ and modified the config.env with the DB password as instructed. Then I ran docker-compose up and it is working great as an upgrade, and my data is all intact.
It might be best to add a note that if a user is running 1.8.0rc2 and has set a different DATA_DIR location, then they need to move the shared folder back inside the same folder as the docker compose files or the upgrade won’t work, and it will act as a new install.
Thank you, both for your time. I hope this post will help someone else when upgrading from rc2 with a different DATA_DIR location set.
@dan@Peter Guys, I am so sorry that I am so thick minded I didn’t notice you were telling me 1.8.0 was released LOL. I for some reason thought you were telling me to install 1.8.0-beta or something. Geez, back to get more coffee.
Well, how exciting, Xibo 1.8.0 is finally released! Congratulations to you all, I know this build has been a giant one!
Thanks again for all your hard work support us users. I truly appreciate it.
