When trying to install 1.7.9 windows im getting a Could not write browser flags to key
\SOFTWARE\Classes\PowerPoint.SlideShow.8.
verify you have sufficient access to that key.
Anybody else getting it or a work around? Tried it on 2 machines same result. Machines are windows 10 pro
We needed to push this via GPO and the MSI will not install at all without manual intervention.
As a work around, I modified the MSI with Microsoft’s ORCA tool from their SDK and removed the registry entries from the installer. Remove both sets of entries from the Registry and FeatureComponent tables and then save.
Just to make sure no functionality is lost, I used GPP to push out the registry settings that were removed from the installer. The Installer now runs without any manual intervention.
