If we have a background on a layout, on some of our devices, all of them Android tablets, the background shows over the single region we have created. The background problem does not happen until the second item on the playlist is shown. Then after that our full screen JPG background that we have used for the past year, is displayed on top of the region. If we remove the background from the layout, of course the problem goes away.
Hi Colin
Yep it’s a known issue but it strangely only affects a few devices. We have an APK with a fix available. I’ll PM you a link. If anyone else needs it please log a ticket directly with Spring Signage’s Helpdesk and they will be able to provide it for you.
Thank you for the quick response, fix, and information.
