I would like to know if the overlaying z-index should works with Xibo Player 2 R201 ?
Because it does not works with mine and I would like to know if it’s normal or not…
Thanks a lot for your help !
Pascal
Pascal
Welcome to the community!
The current Windows player does not support overlapping regions but we do have a pre release available for a new Windows Player that does support this functionality.
As it is a pre release it should only be used for testing purposes and not in production, but do take a look: https://blog.xibo.org.uk/xibo-for-windows-v2/ and tell us what you think.
Thank you
