Your library reference 0 does not exist
Hi
I’m trying to use the embedded html widget to insert a time fetched by api from myzmannim.com onto the display. The code seems to work well when tested on codepen.io however I get the following error when inserted to xibo.
Your library reference 0 does not exist.
Here is the fill code
HTML
<div id="shema-main">--:--</div>
Style Sheet
#shema-main {
    font-size:8vw;
    font-weight:bold;
    text-align:center;
    font-family:Arial, sans-serif;
JavaScript
(async () => {
    const USER_ID = "**********";
    const API_KEY = "***********************************************";
    const LAT = 53.4872;
    const LNG = -2.2901;
    function fetchLocationID() {
        const params = new URLSearchParams({
            User: USER_ID,
            Key: API_KEY,
            Coding: "JS",
            Latitude: LAT,
            Longitude: LNG
        return fetch("https://api.myzmanim.com/engine1.json.aspx/searchGps", {
            method: "POST",
            headers: {
                "Content-Type": "application/x-www-form-urlencoded",
                "Accept": "application/json"
            body: params.toString()
        }).then(r => r.json()).then(data => data.LocationID);
    function fetchShemaMA72(locationID) {
        const todayISO = new Date().toISOString().split("T")[0];
            User: USER_ID,
            Key: API_KEY,
            Coding: "JS",
            Language: "en",
            LocationID: locationID,
            InputDate: todayISO
        return fetch("https://api.myzmanim.com/engine1.json.aspx/getDay", {
            method: "POST",
            headers: {
        }).then(r => r.json()).then(data => data.Zman.ShemaMA72);
    try {
        const locID = await fetchLocationID();
        const iso = await fetchShemaMA72(locID);
        const d = new Date(iso);
        const hh = String(d.getHours()).padStart(2,'0');
        const mm = String(d.getMinutes()).padStart(2,'0');
        document.getElementById("shema-main").textContent = `${hh}:${mm}`;
    } catch (e) {
        document.getElementById("shema-main").textContent = "—";
        console.error(e);
Can someone please shed some light on this?
Many thanks!
Hi @sbleitner , Welcome to the Xibo Community!
Are you using CMS version 4.3.1?
If so, you can’t use array notation, such as [0] , in the Javascript box as this is reserved for Media Library references.
If you need to use array notation, your JavaScript should be put into the HEAD box, inside script tags:
<script> </script>
Thanks! That has solved the issue.
