Hello, for who want to test Xibo 4.1 on a NAS I’ve spent a bit of time to implement Yaml file in “Container Station” of my Qnap NAS. I think it could work also in Synology equipment but not tested.
Install and open “Container Station”
Click on “Applications” and then button “+ Create”.
As “Application name” I’ve put “xibo4” (capital letter are not accepted).
Then copy/paste the below text (yaml):
version: '2.1'
services:
cms-db:
image: mysql:8.0
volumes:
- "xibodb:/var/lib/mysql"
environment:
- MYSQL_DATABASE=cms
- MYSQL_USER=cms
- MYSQL_PASSWORD=Password123
- MYSQL_RANDOM_ROOT_PASSWORD=yes
#mem_limit: 1g
#env_file: config.env
restart: always
ports:
- 3360:3306
cms-xmr:
image: ghcr.io/xibosignage/xibo-xmr:0.11
ports:
- "9505:9505"
restart: always
#mem_limit: 256m
cms-web:
image: ghcr.io/xibosignage/xibo-cms:release-4.1.0
cap_add:
- ALL
volumes:
- "./shared/cms/custom:/var/www/cms/custom:Z"
- "./shared/backup:/var/www/backup:Z"
- "./shared/cms/web/theme/custom:/var/www/cms/web/theme/custom:Z"
- "./shared/cms/xibolibrary:/var/www/cms/library"
- "./shared/cms/web/userscripts:/var/www/cms/web/userscripts:Z"
- "./shared/cms/ca-certs:/var/www/cms/ca-certs:Z"
restart: always
environment:
#- CMS_DEV_MODE=true (in DEV_MODE CRON doesn't work)
- MYSQL_HOST=cms-db
- XMR_HOST=cms-xmr
- CMS_USE_MEMCACHED=true
- MEMCACHED_HOST=cms-memcached
- CMS_SMTP_SERVER=smtp.gmail.com:587
- CMS_SMTP_USERNAME=yourmail@domain.com
- CMS_SMTP_PASSWORD=yourMailPassword
- CMS_SMTP_USE_TLS=YES
- CMS_SMTP_USE_STARTTLS=YES
- CMS_SMTP_REWRITE_DOMAIN=domain.com
- CMS_SMTP_HOSTNAME=domain.com
- CMS_SMTP_FROM_LINE_OVERRIDE=YES
- CMS_SERVER_NAME=cms.example.org
ports:
- "8786:80"
#mem_limit: 1g
cms-memcached:
image: memcached:alpine
command: memcached -m 15
restart: always
#mem_limit: 100M
cms-quickchart:
image: ianw/quickchart
restart: always
volumes:
xibodb:
few information:
- I’ve commented (#) all ‘men-’ setup because are not allowed in Container Station inside the yaml: there is a side menu where I left “unlimited” all the resource
- I’ve commented also the call to external “env_file: config.env”: same reason, not allowed but all the variables had added in “environment” section
- even I’ve copy/paste all the variables in environment they not need to be feed, as per Xibo install instruction
- exposed to host connection also cms-db container: (port 3360) just for my purpose to have a look using Myphpadmin
- all the data are stored in the Nas out thank’s to the setup in “volumes” section.
- select a different version or update to the new one is just a matter to change the image address (image: Package xibo-cms · GitHub).
Finally select “Default web URL port” to easing the access:
Hoping it helps to someone, bye.
