I have upgraded from Xibo 2.3.3 to Xibo 3.3.5 (Docker version).
It seems that the settings for the XMR private address have disappeared from the CMS UI.
Could you please inform me where they have been moved to?
Also, how should I go about configuring them now?
When you use a Docker based installation, the v3 CMS and newer do not require a private XMR address. This is pre-configured for you and does not need to be adjusted.
The XMR public address is the only address you need to set. For more information on how to configure XMR in your Docker based CMS installation, please see this guide.
