I want to be rss with customes xml file. I want to rss view data. How I do this ?
XML Sample
Thank you for your message. You can use RSS feeds with your Xibo Players with the Ticker Widget. I have included a link to the Ticker Widget documentation which provides more information on how to use the Widget:
https://xibo.org.uk/manual/en/media_module_ticker.html
Please note that the RSS feed URL you use will need to be in a valid format for the Ticker to be able to read it. If you find that you are unable to return results, I would recommend using an RSS Feed Vaildator.
