Xibo wont show layouts, using Emteria Andriod Image on Raspberry Pi 5
we recently run into a problem using Emteria Andriod 15 on Raspberry Pi 5. We installed the CMS and set up everything. We have assigned the layout but it is not displayed on the player. It is a monitoring network plan, so nothing special. From time to time this message appears: “Memory running critically low - android will terminate background processes” could it be related to the fact that the layout is not displayed on the Xibo player?
Has anyone here had the same experience?
Best regards.
Hi LeandroBaumann and Welcome to Xibo Community!
My name is Jerry from the Support Team. Xibo Players can’t run on all variants of Raspberry Pi due to couple of reasons which is detailed and outlined in this reference. Raspberry Pi is not listed as one of the recommended hardware for running Xibo for Android. You may visit this reference to check Xibo’s Recommended Android Hardware through here.
Kind regards,
hello
I tried to use emteria android on RPI. but it failed.
I would recommend to buy other device.
