Xibo Widgets Flashing
I’m having an issue with our Xibo Layout where the widgets on the screen will start to flash every 10 seconds.
The issue is the same as reported here: Xibo Player flashes at the end of the Layout
I have attempted to extend the duration and delete and try again, but it’s still having the same issue.
Any Ideas?
Welcome to the community!
Without knowing exactly what you have in your Layout, I would take a guess that it is likely to be due to the Layout having a short duration or multiple widgets with short durations in a Region.
The entire Layout will reload when the Region with the longest duration ends, so you could try increasing the duration so that the whole layout will not reload so often.
