I am trying to upgrade Xibo digital signage from version 2.3.16 to 3.0.0 (and 3.3.3). My database is updated to 5.7 and it was working with 2.3.16 but after upgrade I have this error from logs:
xibo-cms-web-1 SQLSTATE[HY000]: General error: 1364 Field ‘pid’ doesn’t have a default value
I could not find any solution to this. Help please
I manage to upgrade to 3.0.3.
First, if you are upgrading from 5.6 to 5.7 of mysql database (after upgrade):
docker compose down
docker run --rm -ti -v /opt/xibo/shared/db:/var/lib/mysql mysql:5.7 bash
mysqld --skip-grant-tables &
mysql_upgrade (just type the command, you wont see a cursor)
exit
Download the new version of xibo (in my case 3.0.3) and add to your yml file:
