Hi all,
I’m working through some issues with Xibo since an upgrade from 1.4.x to 1.7.4. My players are displaying images, backgrounds, embedded web, flash and HTML fine, but not tickers or text. Nothing appears for those regions at all. you can see from the screenshots below, my test layout has a number of regions (plain text, clock, embedded html, webpage, image, ticker), but in the second shot of the actual player, I see nothing for text, the clock or the ticker.
I don’t see any errors in the info windows on the display:
And the library folder on the client seems to have downloaded all the content properly, I can even open the .xlf file and see my ticker content:
As an Xibo user for about 5 years now, I can say I’ve never seen anything like this, and it’s totally baffling. I’ve enabled debug logging on the server and auditing on the displays. My troubleshoot.txt file is here. And the logging from the display in the screenshot is here, if that helps. Ignore any regional setting errors about en_AU, that’s been changed to en_US.
Any help I can get would be appreciated. I’m very close to having a working 1.7.4 system upgraded from my 1.4.x. The details of my setup are:
Xibo server 1.7.4 on CentOS 6.7 (migrated from old server Running OpenSUSE 11.x)
PHP 5.3.3-46
MySQL mysql-5.1.73-5
Apache 2.2.15-47
Players I’ve tried are 1.7.4 and 1.7.0 on Windows 7 and 8.1, plus the Android trial - same result with all.
Please Help!
