Hello and sorry for my English,
I have 2 television and i d like to install Xibo client on it.
I think the best way is to install Ubuntu on USB key and also the player, it is possible ?
others solutions ?
thanks for help
others solutions ?
thanks for help
The Linux player isn’t developed or supported any longer. You would need to have Windows or Android on a device connected to the TV to run the Xibo Player software. You then connect your device (PC or Android box) to the TV with an HDMI cable.
the Android Player is free ?
do you think is possible install Windows on USB key with the Xibo Player ?
The Android player isn’t free no. You can’t install anything on a USB key and have the TV show it. You need a computer or and Android device which can run Windows or Android, and then the Xibo Player software to make it work. A USB stick alone won’t help you.
