I have 3 xibo player running in 7 centers with kde graphic environment, configure the automatic start of xibo player with the option “auto start” of kde, the only thing I did was choose xibo player and automatically place it to start along with the system.
Hello, you can use systemd for to autostart your xibo player : cat <<EOF> /etc/systemd/system/start-xibo.service [Unit] Description=Service Xibo-client [Service] Environment="HTTP_PROXY=your.proxy:port/" Environment="HTTPS_PROXY=your.proxy:port/" Environment="NO_PROXY=localhost,127.0.0.1" Environment="http_proxy=your.proxy:port/" Environment="https_proxy=your.proxy:port/" Environment="no_proxy=localhost,127.0.0.1" Type=simple RestartSec=30 Environment=DISPLAY=:0 User=xibo ExecStart=/snap/bin/xibo-player Restart=always [Install] WantedBy=default.target
EOF
/bin/systemctl enable start-xibo.service /bin/systemctl daemon-reload
Environments line are optionnal, it’s only if you have an proxy.
User=xibo => use your user (but don’t use root)
