Does anyone have experience running Xibo on the Sony Bravia Pro series ?
Sony FW-65BZ40H
Model no - BRAVIA VH 1
We are facing a very unfamiliar issue.
- the display is able to register with no issues
- default layout plays with no issues
- when we change the default layout or schedule a layout :
we see the content being sent to the display from the cms “manage”. 100% successful download for the files and data, however the layout will not change/show. No matter when we do we are unable to play anything apart from the default layout. Same behaviour when we reset the display and try to get things working again.
Our cms is running fine on all other devices, android - windows - Philips displays - panasoni displays etc. We seem to only be facing this issue with the Sony displays.
I do suspect it has something to do with the storage of the display. As the manufacturer says the display has 16 GB memory, however when we access the storage available under settings, we see only 4GB.
Our setup is the below :
CMS : 1.8.13 (Self hosted)
Player : Android V108
Any help/suggestion will be appreciated.
Thanks,
