Hi all,
Been using Xibo on Windows for a while. Terrific.
I have 3 of these T95Z Plus Android TV devices.
Install was easy - setup the device (network/time/developer/latest firmware/etc.) Installed the Xibo R309 apk. Activated using the code and up and running. (Didn’t add licensing pool to profile, but figured that out when they stopped updating 14 days later.)
My primary issue is that I think Xibo installed itself as the launcher - although I didn’t specify that at any time. When I use the remote to get the action bar, I have the Xibo logo on left, but nothing on the right. So I don’t have the 3 dots. I basically have no way of shutting Xibo down and getting back to Android (to do updates, etc.) I’ve set the Android profile to not start automatically and not restart with no effect. The reset button on the device does nothing (even held down during power on.) The device documentation for resetting the device is to reload the firmware from an SD card (using the reset button/power on.) I’m going to do this, but would appreciate suggestions on how to install Xibo without it becoming the launcher so I don’t end up back where I am (or at least some way to call the original launcher.)
Remote commands work fine. Can reboot. Found “am force-stop uk.org.xibo.client” in some other documentation, but that doesn’t do anything.
Any suggestions appreciated.
