Hi I could really do with some help been a complete Newby to Xibo
I have been running Xibo on a windows 10 computer within Docker for a year using one template pushed to 4 TV’s using firestick Xibo app without issue.
The pc updated the Docker software and now my Firestick apps are all blck screen with the xibo logo in the corner.
I am using windows 10
Xibo 2.2.2.
Docker Desktop 4.1.1 (69879)
In Xibo it says the 4 displays are logged in and up to date and the bars are green
on the TV’s they all have a black screen and a xibo logo in the corner,
My template has 1 video playing, It was working till docket updated and I am not sure how to check for errors
any help would be appreciated
Rob
Specify the full CMS version you are using, including the revision number.
Installation Method
Docker or Custom install
Operating System
The operating system the CMS is installed on
Please describe in detail the issue you are experiencing, including any errors shown in the Logs section of the CMS.
Provide screenshots where possible!
