we got a new Sony Bravia X85L with Android 10 running. Everything works fine, expect the Xibo autostart. On older devices its working without any issues. (cms 1.8.11 / player v1.8 R108).
I’ve set up a test environment with cms 3.3.7 and player v3 R312 but still not working. App-start is activated in the profile and the profile is assigned to the player.
I did a factory reset on the TV and installed the v4_R404. At first it didnt worked. After activating the setting you suggested, it worked Thank you Frazer. Propably i broke something by installing to many versions of Xibo.
FYI another alternative is to go into Sony Bravia’s “Pro Mode” and to specify a custom app to launch at startup – you’d select Xibo from the menu in the Pro Mode – otherwise you could target it by specifying the app uk.org.xibo.client as the app to launch, and you’ll be launching its MainActivity
