Hello Maxim and Alex
So i wanted to try to Contribute, i am a sys admin, and right now i am testing Stivius Forked Xibo-player 0.5.0-Alpha build 2 on Arch Linux Raspberrypi! Sorry if this is not relevant! just wanted to share (Sharing is caring right?) what i found!
So i did a successful compile of the Linux Player on a Raspberry pi 3 B+ with Arch Linux.
I did compile the Linux Player with webkit2gtk-4.0 Version 2.22.5 but i had to do some tweeking to get it working.
Edited Player/CMakelist.txt
pkg_check_modules(WebKit REQUIRED webkit2gtk-4.0>=2.22.5) -
Edited XiboLinuxStack/player/adaptors/WebKitWebViewAdaptor.cpp
Line 4: #include <webkit2/webkit2.h> (Changed from webkit/webkit.h)
Line 41: Need to be changed, this function is not working in Webkit after version 1. (i removed line 41 webkit_web_view_set_transparent(m_webView, true))
Note Maby the correct command webkit_web_view_set_background_color (m_webView, #(not sure how to get this function working. sorry i am not a programmer)#);
(To do the test build on my Raspberry pi i Removed line 41, and did rerun the make command. and it succeeded.)
Looks like this are are the only 2 lines needed to be changed to Upgrade to a newer version of the WEBKIT.
I have successfully started the client, it loads the layout from our Xibo CMS server, Video with audio works, Images, and it shows webpages from another webserver!
Wish you all a great afternoon! XIBO IS AWSOME!
PS:
Here are my temporary notes from how i built the client. sorry they are messy, but its only notes to i can reproduce the system later on:
How i Built my Build enviroment
sudo pacman -Syu
sudo pacman -S cmake
sudo pacman -S boost
sudo pacman -S gst-plugins-bad gst-plugins-base gst-plugins-base-libs gst-plugins-good
sudo pacman -S webkit2gtk webkit2-sharp
sudo pacman -S gst-libav
sudo pacman -S patch
sudo pacman -S bison
sudo pacman -S flex
sudo pacman -S GTest
sudo pacman -S gmock
#Install spdlog
yaourt -S spdlog-git
mkdir DEV
cd DEV
git clone https://github.com/Stivius/XiboLinuxStack.git
cd XiboLinuxStack/
mkdir build
cd build
cmake …
make
#Here i got error messages and needed to do some tweeking before running make command again:
Edit
/home/archpi/DEV/XiboLinuxStack/player/adaptors/WebKitWebViewAdaptor.cpp
Line 41: Need to be changed, this function is not working in Webkit - 4.0(i removed line 41 since i do not understand what command to replace it with)
I think this could be the correct command webkit_web_view_set_background_color (m_webView, something);
(changed from: webkit_web_view_set_transparent(m_webView, true); )
####NOTE from internet: https://webkitgtk.org/reference/webkit2gtk/stable/WebKitWebView.html#webkit-web-view-set-background-color ####
GdkRGBA
typedef struct {
gdouble red;
gdouble green;
gdouble blue;
gdouble alpha;
} GdkRGBA;
A GdkRGBA is used to represent a (possibly translucent) color, in a way that is compatible with cairo’s notion of color.
Members
gdouble red;
The intensity of the red channel from 0.0 to 1.0 inclusive
gdouble green;
The intensity of the green channel from 0.0 to 1.0 inclusive
gdouble blue;
The intensity of the blue channel from 0.0 to 1.0 inclusive
gdouble alpha;
The opacity of the color from 0.0 for completely translucent to 1.0 for opaque
