Is there by chance a guide on how to get this type of configuration going? At this moment in time I am stuck trying to assign the appname to the AssignedAccess but I have had no luck. Not quite sure what the best course of action would be if Xibo Players can be deployed in Kiosk mode with a local user that auto logs on and never displayed the task bar. Any thoughts?
I appreciate the fast reply! I have been referencing the posting that you supplied the link to, however there are a couple of differences that are posing issues.
Would it be possible to use an Active Directory account as the “kioskuser”?
In the link you provided, you state that the system will auto logon as the kioskuser, but where are you explicitly stating that account to be the autologon account?
And just to clarify, I am using Windows 11 Enterprise.
Hi there, I am searching for the same solution. I installed Xibo on the device but the application closes automatically and in Xibo watchdog I have an error message:
I’d check your directory and see if the that folder is writable. If you’re using kiosk mode, then shell launcher handles the xibo player so you can rename the watchdog file.
