Xibo installation problem on debian 9
I’m a student in the digital system.
My job is to install a xibo.2.3.3 on a debian 9.
But I have a problem, once the xibo dependencies are installed, I don’t have access to the rest of the installation : “The requested URL was not found on this server.”!
Capturexibo|690x302
I need help.
Thanks.
Thank you for your message and screenshot of the issue. I would recommend checking if you have a webserver such as apache already installed on your Debian 9 machine. If you do then you will need to either remove it or ensure it does not conflict with your Xibo install by using an alternative port.
